To my friends and 4Runnertiers!
I've been going nuts looking up and down this (and other forums), mechanics manuals, and I may have finished the web at this point.
I come to you with humility and a sense of pride that someone on here may have an answer or various answers I can test out.
The
Multi-terrain Select Indicator and
Four-wheel drive indicator lights are flashing. The first slower than the second, but both flashing.
I have a 2016 4Runner Trail Premium.
Here's what I've tried so far:
- Put the 4wd mode selector to 4Lo. Drove in Reverse for 100+ ft. Also drove forward for 100+ ft Did the same for 4Hi. Tried this a few times over. No luck.
- Checked the fuses, both in the car cabin and in the engine bay.
- Scanned and cleared any and all codes a few times using a BlueDriver Bluetooth OBD2 scan tool.
A few questions:
- Could it be a relay? If so, which one?
- One of the wires loose on the ABS or other sensors?
- Traction control messed up?
- Any relation to a parking brake bypass switch I've added to my aftermarket stereo (Pioneer AVIC8200-NEX)? I've had the switch for a while, but fiddled around with the radio and wondering if there's any causation.
- Related to the Pedal Commander I use?
Many thanks in advanced!
Rob
